RjFabWerx
Hope I've posted this in the correct spot...
Ok, I'm planning a project here and want to be sure I'm looking for the correct parts...
I'm putting a 302 in my '86, 4x4, extended cab, short box Ranger...My question is what transmission should I go with in order to keep my 4x4...I have been told the C-4 would be a good option but I'm trying to figure out how that would work with keeping my 4 wheel drive when the C-4 its out of a car...other guys have told me to go with a C-6 out of a 4x4 and run the np transfer case with it and that it would be a bullet proof combo...
If this helps, the 302 is currently bolted into a 70's, 2 wheel drive Ford pickup so if there's any difference in 302's, that's what it's bolted into right now and I'm about to pull it out...
I just need to know exactly what will work and what I will be able to find adapters for...I have the websites for the adapters, etc...I just need input about what will be the smoothest swap and basically WHAT WILL WORK in order to keep my ranger a 4 wheel drive?
I'd just like to know what you guys have done with this and how well it worked out for you...
Thanks for any and all information!
Rj
Rj
