Dunderberg
- Feb 15, 2015
- My credo
- visa, mastercard
1990 B2 4x4 5speed with stock MAF system:
It died on the road- a couple of hiccups and ten seconds later engine died. Engine cranks, no start.
There was one code (don't remember the #) it said something about secondary fuel pump relay problem. Both Fuel pump and ECU relays operate when triggered manually. Key-on, fuel pumps do not prime. When the fuel pump relay wire at the ECU harness is grounded, the pumps work fine. Perhaps there is a failure in the ECU grounding the relay? A general grounding issue? Or the TFI is bad (but wouldn't the pumps prime as the TFI wouldn't be sending a cranking signal at that point?) or am I off base with this assumption? Or something else? When ECUs fail do they give a self diagnosis failure code or warning? Any ideas? Thanks for reading.
