Ecm compatibility
Scott_Meier
Eureka
I have a 93 ford ranger 4.0 manual no egr how do I find out what computers are compatible so I can get one out of a salvage yard....
Here are the choices. 2x4 or 4x4 matters according to this list.
Electronic Control Module, 6-245 (4.0L), 4x2, AT, ID F37F-MA
Electronic Control Module, 6-245 (4.0L), 4x2, AT, ID F37F-PA
Electronic Control Module, 6-245 (4.0L), 4x2, AT, ID F37F-VB
Electronic Control Module, 6-245 (4.0L), 4x2, AT, ID F47F-ZC
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-KA
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-LA
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-TC
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-UA
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-UB
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-UBMR
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F37F-UC
Electronic Control Module, 6-245 (4.0L), 4x2, MT, ID F47F-ZC
Electronic Control Module, 6-245 (4.0L), 4x4, AT, ID F37F-NA
Electronic Control Module, 6-245 (4.0L), 4x4, AT, ID F37F-XA
Electronic Control Module, 6-245 (4.0L), 4x4, AT, ID F37F-XB
Electronic Control Module, 6-245 (4.0L), 4x4, MT, ID F37F-LA
Electronic Control Module, 6-245 (4.0L), 4x4, MT, ID F37F-UA
Electronic Control Module, 6-245 (4.0L), 4x4, MT, ID F37F-UB
Electronic Control Module, 6-245 (4.0L), 4x4, MT, ID F37F-UBMR
Electronic Control Module, 6-245 (4.0L), 4x4, MT, ID F37F-UC
Ok so any one would work that's a 93 4.0 4x4 but sense I put a manual shift in mine would the 4x4 4x2 part matter?
2WD vs 4WD shouldn’t matter. The ECM doesn’t have any control over the 4x4 system.
pi
[/QUOT
Why does the salvage yard tell me only 2 other computers will work what would be so different min is a uc .. and they said vb ... and Uber will only work wtf any ideas
salvage yard is using a database like Autodex North America and it is super super exact. They will only list the exact same part number. So if Ford made a part and gave it part number XY-1234, then 5 years later improved it and replaced it with a new versions XZ-1234 (note the Y and Z), the junkyard will still tell you ONLY XY-... and not give you vehicles with the XZ-... parts.
Not to mention a XL and XR both work perfectly fine, that is just the slight version different that Ford used in a CAR/SUV that had one additional feature that doesn't exist on ours and the computer ignores missing with no errors.
Ok I didn't know how that worked i thought I was screwed thanks for explaining so i just need to ignore them and just get one for my year n manual transmission.... tho that motor is a salvage motor and was out of a automatic n I was getting a natural switch code but I couldn't find the wires .... then I started getting the ecm 511 i think code pin 1 something I pull the computer out n seen the board burnt under the blue chips
you can cleanup and re-cap (replace capacitors) for little of nothing cost...
Yea I grew up working on chip boards but the board is burnt under all the blue ones
@Scott_Meier
In both 93 and 94 Ford produced 2 different 4.0l setups:
• the SFI-MAF/EDIS with EGR (the California emissions, sequential fuel injected version)
• the MPI-MAF/EDIS non-EGR (the Federal, batch fire version)...the PCM from one system should not be used on the other.
@Scott_Meier
Well idk what I got i ordered the F37F-LA from a salvage yard yesterday
