eccentric bushing intall and BL ?'s
1986b2
i just bought some moog eccentrics for my b2 after doing a washer lift ..how do you install these? and also how much body lift can i do without extensions?
The bushing should have the instructions with them... But you pretty much ahve to remove the spindles to get the buggers in as they are what the upper ball joints set in. As for the BL 2 inches is about the max I've seen that did not require extending anyhting and IMO that is a far as you want to go with a BL unless you are putting in a 302.....
alaska...so i will not need extensions with 1.25-1.5in of body lift?
