eb suspension question??
rangerdestroyer
so im looking to do an eb (70's) dana 44 and 9" swap on my 92 ranger reg cab im just wondering if its as easy as what people say. what kinda fabing is involved in doing this swap. im told that you can preetty much cut the ranger suspension off and the eb parts bolts right up with little to no fabbing. does the trac bar just bolt into place or fabing. If anyone can help me on this :icon_confused: :dunno:
The trackbar will need a mount made or maybe bought and either bolted or welded to the frame. Your wheel bolt pattern will change too. There is more to it yhen meets the eye but nothing non to difficult. I would try to get an axle with front disk brakes on it already.
What do you plan on using your truck for after the swap?
If you go with with James Duffs extended radius arms, and track bar mount, EB/RBV coil buckets, its a pretty much bolt on affair. But thats all big money....
Otherwise you will need to buy either a premade trac-bar mount and fab it to work for you, or fab your own trac bar bracket.
Also, you will need to fab a tranny mount and possibly either mod the current buckets to take EB coils, or buy some generic ones (but will still require a minimum of fab possibly).
Its not hard if you know how to use a torch, grinder and of course you know how to weld good. If you don't, it'd be a pretty duanting, time consuming SOB.
Course, if you have buddies that will do the above for some :beer::beer::beer: then you are all set to go once to gather the majority of the parts.
Also, this is not a over the weekend project (for some it is, but for most it is nto). If you know what you are doing count on 1-4 weekends or 2 weeks solid(ish, all persons take a different amount of time). The most time consuming part, is the research involved to figure what to buy, and what to do with what you buy.... If you have never done this thing before, get another DD, and park the project rig for an extended period of time. Crap always creeps up, and the proccess will always taking longer than expected...
:icon_thumby::icon_thumby::icon_welder::icon_welder:
James Duff had been working on a kit that would allow swapping of a solid axle into RBVs, though last I heard they were caught up on the trackbar bracket and I haven't heard any further on it in awhile, so like mentioned, you may have to do some fabbing on it.
Also keep in mind the EB D44 front axle (aside from the front brakes) is not an upgrade from what you currently have under your '92 unless you swap aftermarket shafts into it that have the bigger u-joints. Same goes for the 9" rear if you have an 8.8" now, it's right about the same thing with it's 28 spline shafts.
It is a more involved swap than just cutting stuff off and bolting stuff up. First you need to decide what size tires you want to run and what you want to use the truck for. Set a budget and then double it.
You can call JD and talk to them about the swap. Lots of good info and they will help point you in the right direction. If you got about $1200 you can bolt it right up with their parts. I have the first kit they made on my explorer and my friend Trevor (Foxracin) has the second. Check his build thread in the under construction section. He has put way more miles and beatings on his setup than I have. Not to mention his is also a daily driver.
Make sure to have disc brakes on the front axle. Either stock or by one of the many swaps available. The trac bar bracket is a part not to take lightly. Overkill is the way to go as this is the part that locates the axle under the truck. Stay away from the steering box area as it already sees enough stress. You can mod your stock x-member or build a custom unit.
Just call JD and talk to them. They have been doing a lot of work on this since first doing it on my explorer. They have also done the SAS on a full-size bronco and are getting ready to do it on an IFS Sport Trac for the newer gens.
If your not wanting to go full width on your truck, then I would narrow a high pinion full width D44 axle and then go from there. The EB axle is a low pinion.
im looking to buy all suspension parts from broncograveyard and mount to the ranger would like to run 35" for now than move up to 38" or bigger.
I dont know how well a D44 would hold up to 38's let alone an EB one doing it. If you plan on going with 38's later, put a D60 under your truck now.
Well if you are going to buy all EB suspension pieces and try to mount that to your ranger then you will have some serious fabbing involved.
If you're going to spend the money to buy parts, why not buy parts that bolt on to your ranger??? If you have to fab them to fit anyway, use junkyard parts.
Agreed, 38s are seriously pushing the limits of a 44. By the time you upgrade axles and such, you could have put a 60 in.
So what's the deal? Did they finally get the trackbar bracket issue figured out?
I dont beat on my shit. Its a mall rated daily driver.:icon_confused:
By the way I just noticed this:
Used For: bending shock mounts and picking up mountain whores
Thats some funny shit right there.:icon_rofl:
You mean this:
Couple people have them already. Call and talk to them and you may be able to get one.
Wasn't actually looking for one, just was wondering in case anyone asks in the future (last I heard they were still working some bugs out or something).
Good to know that it's finally out, thanks for the info
What I'd REALLY like to see is pics of the Sport Trac they're working on. A SLA-IFS > SA kit IMO is something sorely-needed here in the RBV world. :rockon:
AFAIK the Sport Trac is supposed to roll in within the next month or so.
Trevor and I saw it when we met up at Duff's before our Windrock trip. I think it is an '01 model? Trevor, you remember what he said?
After looking it over I believe the ifs trucks will be easier than the TTB ones. The frame is boxed all the way back to the doors. Hardest part will be cutting out that damn X-member that the rack bolts to. Use a Toyota or Nissan xterra box and be done with it. Trac bar bracket will be much easier. Use a standard bracket for a boxed frame. Duff already has the coil buckets they use for the 4 link kits to set the ride height wherever the customer wants. I'll see if I can get more info at a later date.
BTW, for the FaceTubers out there. They are hosting an open house July 30th. Trevor you should come over and show off your ride. They sent me an invite today on the Facebook.
The trackbar mounting seems to be the biggest issue when it comes to doing a SAS but alot rides on it.
I will say that there would be a huge market for a bolt in SAS kit for RBV's. Them making a kit would take the "is there a bolt in kit" out of the question.
