- Aug 6, 2007
- Age
- 37
- Plattsburgh, NY
1999
i picked up a 1975 bronco for 300 bucks.. i pulled the front axle for my 95 ranger. it had a 4 inch suspension lift i cut the coil buckets off and bought new f250 shock towers. ive bee doing my research and got most of what i need to know figured out.. it came with disc brakes.. that only came with with 76-77 axles. well the axle is stamped 1975. but the trac bar takes the 76-77 bushings.. so iam not entirely sure what year it is. the issue iam trying to figure out is my steering. can i use most of the factory steering linkages? or what would be the cheaper solution. i have to buy one of the steering links for the driver side due to it being bent.. i found a replacement for 105 but trying to weigh out my options and see what would be sufficient. iam currently rebuilding the axle and this is my only issue so far. thanks guys..
