mounties83
I seem to be refilling my coolant a lot...but its not smoking or anything but i do see the occasional coolant puke...whats causing this?
No belt squeal at all
I had the same problem till the other day when my motor blowed up, it blowed up real good. It overheated a month ago after the power steering pump seized . After replacing the PS pump it seemed fine but started to eat some antifreeze, I thought it was the cap because there would be fluid leaking out. Was driving the other day and it let loose without warning, no idiot lights no CEL no temp warning. Hope your problem is different, good luck
