- Jul 16, 2008
- Bridge City, Texas
- 4.0 V6
- Automatic
I am in Phase one of the E85 conversion.
P1 inclusion:
run ability of stock engine on various blends of E85
P1 base engine:
1993 3.0L 182K miles.
one set of heads at 126k miles due to stuck thermo
to my knowledge, stock timing chain
(may lead to retarded valve timing and reduced efficiency of E85)
maybe a liter of stop leak for the radiator strategically transferred to the engine oil
(it was cold and i was hung over so i didn't bother changing the oil during the head replacement)
factory 3.73 and 5 speed
LT235/75R15 uniroyals
Stock suspension
(though i have given serious consideration to the F100/150 fwd coil spring swap.)
Driving: Rt 3 to 255/270 west crossing the JB bridge.
exit at Telegraph then 3 miles north to Hoffmeister.
Any south east metro STL folk wil know my drive.
So far I am able to run 40-45% with good results, Anything more than 45% E85 an the engine gets testy
I have decided that the compatibility of the E85 to a non E85 vehicle in respect to hard parts and seals is acceptable, at least for the vehicle i drive" 1993 Ranger Xtra Cab 4x4.
Phase 2 would include building of an engine designed especially to reap the benefits of E85.
2002-3 pistons with domes, 1996 heads with 47cc chambers and any crank after 1996 which has 5 counter weights (simply because vibrations are bad, and a high revving motor WILL make vibrations).
I have yet to decide if i should "mess with" cam specs. perhaps that should be best waited upon until the results of initial P2 is complete.
And so...... since i have put this idea of mine out there, I hope to hear any and all opinions, whether in support or ridicule. Perhaps some of the readers could come up with ideas how my plan may be improved. I can learn from even the nay sayers.
So... Flame me or support me, but please don't just read and bounce. Post a response. This is the only way we learn.....
Thank you in advance!
Rob
			P1 inclusion:
P1 base engine:
Stock suspension
Rob
	 Welcome Visitor! Please take a few seconds and
		 The ultimate goal is to create my own ethanol to burn in my personally converted Ranger.
