eightynine4x4
- Oct 15, 2020
- New York
- 2.9 V6
- Automatic
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
Might do this upgrade:
Here's the instructions for the adjustable thermostat kit..
Installation Details
"Locate a 3/8” NPT port either on the radiator, waterneck,
intake manifold or cylinder heads."
Silly question, but this sender tech works just as well when it's just basic metal to metal contact to the engine, correct? No need to take readings directly from the coolant? Reason I ask is because maybe the port near rear of intake manifold can be used. And maybe some thread adapter if that hole is larger. Would be quite a long lead though, from rear of engine up to fan electronics.
