DURAspark wiring questions
stevenstosz
duraspark conversion question,, the wiring diagrams show the ignition module[ blue grommet] to have six wires . A two pin connector WITH the red and white to power the unit. Now for the four pin connector,
[ARTICLE SAYS green goes to the neg. side of the coil.]
my green wire is the bottom one. The diagram SHOWS the green wire being the forth one from the bottom. Do I go with the green colored wire or the fourth wire from the bottom which in my case FROM THE BOTTOM UP
----------WHITE
----------RED
---------------PURPLE
---------------ORANGE
---------------BLACK
---------------GREEN
Green to coil neg. Are you using the stock square coil? If so key on hot goes to red and coil pos and just run a wire from the starter side of the start solenoid (key on start) to the white wire. The black is ground on the dizzy. The purple and orange are the pickup coil in the dizzy. The white wire just retards the timing for a quick start.
Thank you for your time! so it is all about the color. The order that they come out of the module is irrelevant. I've made up a harness and ready to go. Thanks again
