- Aug 23, 2007
I took out the entire harness to the computer and got the relays and all the vacuum lines out. My question is do I need to keep a few of the wires that go that way for the sensors and gauges, or can I just use the wires from the driverside? Would they supply all of the power and grounds I need for the lights and gauges?
This isn't a pinto duraspark BTW, I am using an analog GM modual ignition from a 78 camaro 350 and a normal 3 wire distributor and non feedback 2150 carb.
