I decide to start working on my ranger again. I'm to the point that i need to hook up my electronic ignition. I am using a 70's duraspark box. I was wondering
witch of the plugs in the pics below i should hook into. Any info would be appreciated. Thanks.
Hey Phil,
No on the EFI. I am just running an old 70's model distibutor also.
I read in the tech pages there was already a hook up for this but
did'nt see one. Thanks, Brian
The red wire on the module needs 12v switched, as does the positive side of the coil. You can tap into the cranking circuit wire and hook it to the white module wire if you want it to retard the timing while cranking.
For
