03ranger4x4
- Oct 16, 2009
- Automatic
hey, the CDI box on my kawasaki lakota 300 went bad, and im installing a durapsark box in its place (the one from an 83 ranger if that matters)
My question is, will you burn out the duraspark if you wire everything up, but accidently put +12 volts to the green lead directly? I mis understood how they ran the wiring harness in my atv, and relized the yellow/red stripe wire i connected to the green "coil" wire on the duraspark was a hot 12 volt lead, and not a lead for the coil on the bike. I noticed the duraspark box got a little warm, but its hard to tell if it did damage.
Anyways, i wired the duraspark up correctly (red-12volt blk- ground purple and orange wires to the two leads from the ignition stator on the engine (which would be equal to the sensor in a distributor it would normal be wired to) and lastly the green wire to the Ground side on the coil (NOT the 12v side lol) and im not getting a danm thing. SOOOO i would like to know if i burnt out the duraspark, or if not, then it just isnt compatable with my atvs ignition system.
Im about to go buy another duraspark and try it and if i get no results, i suppose it can simply return the 2nd one (the first one i cut the connectors off, so cant really return it)
ALSO, one more thing, is a "ballast resistor" required for the coil lead or not? I saw a wiring diagram with one in it, however the atv did not orignally have one.
here is a diagram i looked up on how to wire the duraspark to the atv, for those who have trouble understanding what im talking about if you are unfamilar with atvs.
http://rthompson.us/wp-content/uploads/2007/02/atv-wiring.gif
