I hooked up duraspark II ignition on my 2.8 and it runs great. One concern tho is that my coil is geting really hot. I tried diffrent coils. I'm guessing its mayby a ground issue. Any feedback would be great.
Are you using the stock square coil. If the ground was bad it probably wouldnt work very good if at all. You may need to add a ballast resistor if your using a after market coil to cut down the voltage going to it.
For
