ok guys i put a duraspared 2.8 in an 87 body and i cant get the thing to stay running unless i hold the key in the crank position. so what i need to know is if i can just run the coil and the ign module to toggle switches? if so i need a detailed exp of how to wire it up. i know the coil should just be on/off but the module has 2 power wires hot in start and one hot in on right? im also gonna put a push button starter on it.
