- Oct 2, 2017
- Saskatoon
- Manual
- My credo
- hard and fast
So I've got it all done, can get it started and when it does start it runs better than it ever has under my ownership. BUT.....no spark on start. I have spark on run obviously but that's it. I found the brown w/pink that has 12V power in start but nothing in run, then I found a red with no trace that has 6.8V in run and nothing in start. Could not find the red w/light green as mentioned in the write up though.
So the question is, can I tie these two wires together? Or am I looking for a fire??
Ok I just found an electrical drawing on here that shows the red w/green and brown w/pink intersecting at a node, so I should be good with tying these together....I hope. Still makes me wonder why I have no power in run at the brown wire. And I'm a little concerned about the low voltage in run from the red wire......
