johnnybronco
Anyone know if the t-case for a manual tranny is the same for an automatic? I've got the dummy t-case and having a hard time finding a replacement.
why do you call it the dummy case???? is it true that ford put t-case on these things that really wasnt a t-case but a decoy???
It was a BW 13-59. Externally, it looks like a 13-50 but the front output is sealed off. Internally, its just a strait through shaft to the rear.
The only explanation I can come up with is that the Bronco II drive shafts were kinda screwy and probably not the cheapest thing in the world to produce. It may have been easier/cheaper to put the dummy case on than to engineer a drive shaft that worked with a 2WD trans.
