fordwheelinman
- Aug 6, 2007
The thought just reappeared in my mind of converting my old 78 to a dually when i put my flat bed on, true i loose my bitchin wheels and 33's, but itd be kinda fun, and technically would still increase my traction over stock (which will be much needed if i decide to swap my 400 for my 460). I cant recall any one suggesting this before, and if they have i apologize. But what if you were to take a set of true dually rims, cut the centers out, and weld in a new center with your bolt pattern on it? You would be transferring the load from both wheels directly to the wheel mounting surface. You wouldnt be extending anything of the axle over stock length. You wouldnt even be using any of those store bought adapters that many people dislike.While it may not be the most simplistic idea, it seems to be the more correct way to convert a SRW to a DRW without actually swapping out for a dually axle, which we all know is the true correct way. Let me know what you think, good, bad, im a dumbass shut the hell up, im open to all thoughts here. FWM.
