dual tank incoming hoses, front back, top botom?
Angie
Vancouver area BC Canada
92 & 83 project
Setting the lines into the frame of the truck. Any one know if the top hose is the front or back tank? 1983 ranger. thanks. (truck is not together nor running so i can't test it before the build is finished).
I would think the upper line would go to tank farthest away
If you are going to add fuel injection you would need 2 fuel lines for each tank, just a heads up.
Hi Ron, Thanks for the reply.
At the moment I have the top inlet going to the front tank, it's 50/50 to get it correct and not a big deal to switch around when we get this truck complete, (just a pain in the @ss to do). Was hoping someone knew for sure and saved the headache later.
It will be 600 edelbrock sitting on top.
cheers
