Dual headlight help
b411sac
U.S. Military - Active
Ft. Drum, NY
So I have these headlights on my truck, and HID's in the reflectors and the projectors, I have the H3 projectors as the main headlight, controlled by the stock headlight harness, which leaves me with no brights. I was wondering if you guys had any idea how to wire it so I can power the reflectors when I activate the brights. And possible still leaving the projectors on.
One quick question. Is the main headlight harness plugged directly into the projector so no matter what the projector is on whether the switch is in the High or Low position? If so you can get a relay and wire it like this picture. I drew it the best I could in MS Paint so if you have any questions just ask. If it's wired different let me know and I can adjust accordingly.
I see what you are saying and it should work, I'll just have to try it, and I'll let you know how it goes. This weekend.
Sent from my DINC2 using Tapatalk
