So I couldn't decide if this fit in transmissions, or 4x4 tech, or axles.
So, I just finished putting my lift on in the rear and it netted me 1.5" with shackles, and 3" with AAL + stock 2" blocks = 6.5" of lift total.
Now I have a shudder from acceleration until about 10 mph. I figure its the drive shaft angle. My question is, what's the proper way of doing this?
I didn't look, but is that cross-member bolted in or riveted? Can I just install some 2" 1/4 tube as drop brackets/spacers?
On to the next problem. My camber issues.
In this picture the truck is sitting with a bit of negative camber. As soon I start driving a serious issue of positive camber comes. I'm talking probably 5+ degrees.
I'm running an older superlift 5.5" kit with 1" spacers. You can also see it has some rake in the picture, but once I drive and park it, it's level and all whacked out.
I'm buying some Moog adjustable 4 degree bushings and see if they help any, if not I'll just remove the spacers and run smaller ones.
Wait...I think I know why I've got issues, it's got some toe in, so there fore the toe in wants to push the truck up...I back the truck up the driveway resulting in driving with toe out causing the truck to drag the front downward...
