Kinda following the skyjacker install instructions from the tech library on this one. However I bought a used lift that I am 99% sure is superlift that didnt come with any nuts or bolts.
Im picking up some hardware to bolt the lift on. I will be using grade 8 1/2 inch bolts for the radius arm brackets. Was planning on using the same size to mount the drop brackets but the holes in the drop brackets are quite a bit larger than 1/2 inch.
Do I need to go with bigger bolts here and drill the crossmember to match???? I would imagine using 1/2 with these larger holes could cause exessive play or other bullsh*t problems like loose brackets. Any one else install a superlift and have the same problems.
