DRL delete?
Usually there is an option to turn them off somewhere. I'm not sure about Canadian cars though because their laws are different.
Removing the DRL module and retaining the Hi-Beam and Parking Brake indicator lights is fairly simple, a couple jumpers on the DRL module connector is all that is required.
Jumper 1: Pin 1 to Pin 8 - this will connect the headlights to the headlight indicator lamp.
Jumper 2: Pin 3 to Pin 6 - this will connect the parking brake switch to the parking brake indicator lamp.
Connector C170 pinout (looking into the end of the connector)
-(5)-(6)-(7)-(8)-
-(1)-(2)-(3)-(4)-
Pin descriptions:
(1) - Hi Beam Indicator Output
(2) - Ignition Input, hot in run
(3) - Brake Indicator, DRL disable output
(4) - Battery Power Input, always hot
(5) - N/C
(6) - Parking Brake On Input, to parking brake switch
(7) - Lo Beam Input
(8) - Pulsed voltage to Hi Beam output.
See the attached pdf's they show the circuit diagram and the connector pinout.
This should hold true for 93/94 vehicles, not sure about any other years.
Good Luck!:beer:
