birddog321
Got a B2 a while ago, Ran like crap but the price wqas right. Got it home found out the Fuel system was full of mud. Replacxed Fuel Filter, Pump and used pump to flush out the lines. Still ran like crap. Checked compression and found that it was only &0 PSI all the way around. Had the heads checked and rebuilt. (Previous company did a really Sh8t job) New head gaskets and still bad compression. Got pissed and pulled the engine. Found pieces of oil rings in the oil pan. Found a donor at the pullapart for bottom end. replaced engine and now I have good compression but trying to get it started after putting it back in found that the dizzy wan"t working. Changed dizzy and got it to fire up. Noticed though that the spark plugs were covered in gas. All injectors are firing as they should and are not leaking. Good spark allthe way around. I am ready to junk this thing but I have too much $ in it now.
Any suggestions would be great
