jbanderson
- Jul 29, 2009
- Automatic
My trck just suddenly started vibrating from about 50mph to around 60mph (witch ofcourse is the speed i travel at all the time!!!!)... and under hard acceleration in all the way through 1st gear and some of 2nd it will make a pop pop pop pop pop pop pop pop sound kinda like a faint metal to metal pop.. When I put it in reverse or drive it will make a LOUD POP!
I thought it was the pinon bearing but I cant seem to see any slack in it when i pry on the driveshaft, the U joints look fine and dont seem to have any play in them either. Its a 4.0 regular cab short bed with 8.8 rear. Is there a place to grease the splines on the driveshaft? It has 245,000 miles on it.
thanks
thanks
