driveshaft swap problem
fordman49450
Michigan
ok I have a 94 ext cab ranger 4x4 with 4.0, M5OD Trans with a electronic shift transfer case. I bought a 1 piece driveshaft for a 98 ranger ext cab. The rear flange for the axle bolts right on but the front where it bolts to the transfercase is a bigger bolt pattern then the transfercase flange. I was going to change the end on the driveshaft from the old to the new but the U-joints are different. the old driveshaft has a u-joint that is 3.25" approx from cap to cab on both axis's. without the caps it is approx 3". the new replacement driveshaft ujoint is 3 5/8 from cap to cap or approx 3 5/16 without the caps. the caps on both driveshafts are 1 1/16. SO I guess I need to get a u-joint that is the same on one axis as the old driveshaft and the other axis needs to be the same as the new one so I can put the old driveshaft flange on the new one. If anyone can give me a part number this would be great as none of the parts stores here are of no help at all even with measurements. Thanks.
It also was brought up just as this article was being finished that later Supercab 4x4s fitted with aluminum shafts have a larger T-case flange (same as the larger rear flange with 3" bolt spacing). These will require either swapping the forward U-joint piece or swapping the t-case flange. --4x4junkie
Looks like there are some other things you will need to do as well, here is the article on how to do it:
http://www.therangerstation.com/Magazine/June04/offroad.htm
ok, does anyone know if the flange from the transfercase off of a 98 has the same size hole and same spline count as my output shaft on the transfer case of my 94? thanks
Yes It Should Bolt Right On With No Problems
The transfer case flange bolt pattern on your '94 is 2.5" across from bolt to bolt. The 98-99 flange will be the same. If the 1-piece replacement is 3", it is not from a 98-99, but rather a 00+. In this case there are a few things you can do...you can change the transfer case output shaft flange and swap it out with the correct 3" part, or you will need to track down the correct u-joint stub flange on the driveshaft itself with a piece from a junkyard and use a conversion u-joint. I believe this would be a Spicer 1310-1330 conversion joint, part number Spicer 5-134X.
I have found a solution. It is the 1310 to 1330 ujoint. Thanks guys. I really do appreciate all of your help.. Good thing I cut the rivets and not the plate for the midship bearing since I had to reinstall the old driveshaft untill I figured out the problem.
