noslofiveoh
- Nov 6, 2009
ok, just the other day my rear u-joint failed and dropped the shaft resulting in un useable condition. anyway i cant track down a replacement shaft (sounds crazy but they don't exist here for some reason) so i can either have a new end welded on and balanced for about $100. or i can try and track down a 1-piece shaft and do the conversion from the tech library. not sure which way i should go with this. also my truck is an 88 supercab and has a 4 inch lift on it so it has a bit of drive shaft angle. which way would be better for durability and longevity?
