TheRob
- Jul 23, 2009
For the past few weeks, I've had a grinding noise that sounded like the brakes being stuck on. It was intermittent and went away pretty much when I hit the brakes. Thinking it was brakes, I had a shop look at them (I don't know about drum brakes yet, unfortunately). Everything was cool. So, today I went under to see if the driveshaft was having some problem and lo and behold, a big ass metal cylinder is hanging on the driveshaft. It has some holes partially drilled through it and rubber on the inside, and it's located almost directly behind the transmission. I'm assuming this is a harmonic dampener for the driveshaft. Is there a way to reattach this piece, or is the driveshaft just done? If it's done for, can someone give me a short lesson on how to change a driveshaft? I don't have MUCH knowledge about RWD vehicles, so this will be a new operation for me.
Thanks,
-Rob
Thanks,
-Rob
