Wanted Driveshaft (1pc newer part to retrofit in 89 Super Cab)
kishy
5+ Year Member
ON, Canada
I have been trying to track this down locally and keep striking out, so here goes:
I have an 89 Super Cab RWD truck which I need to swap to a one-piece driveshaft.
I believe that the driveshaft I need will come from a 1998-2011 RWD Super Cab truck with a manual transmission.
I have a 2000 pinion flange so the larger bolt pattern should be a non-issue, but I will need the rear yoke.
If you have an appropriate driveshaft and you are within a couple hour drive of Detroit, MI / Windsor, ON, let me know and maybe we can set something up.
If you have more specific information about applications that can give me a driveshaft I'll gladly take that info as well.
Much appreciated.
From car-part.com:
I'm pretty sure you're right on the application. There are also steel and aluminum driveshafts. The aluminum one is much larger so might have clearance issues.
From car-part.com:
Thank you, but I'm hoping to buy this item private sale. I have a series of reasons why I'd prefer that, and without meaning to write a novel...basically I'm not interested if the vehicle was processed with a fork loader, I'm not interested if it has to be shipped, I'm not interested if I can't pay cash in-person after seeing it, and I'm not interested if I have to conform to typical business hours to get it.
I'm willing to spend the drive time and fuel, just need one to turn up.
I have a steel one and an aluminum one in central OH
