Wanted Driveshaft (1pc newer part to retrofit in 89 Super Cab)
kishy
5+ Year Member
ON, Canada
I have been trying to track this down locally and keep striking out, so here goes:
I have an 89 Super Cab RWD truck which I need to swap to a one-piece driveshaft.
I believe that the driveshaft I need will come from a 1998-2011 RWD Super Cab truck with a manual transmission.
I have a 2000 pinion flange so the larger bolt pattern should be a non-issue, but I will need the rear yoke.
If you have an appropriate driveshaft and you are within a couple hour drive of Detroit, MI / Windsor, ON, let me know and maybe we can set something up.
If you have more specific information about applications that can give me a driveshaft I'll gladly take that info as well.
Much appreciated.
From car-part.com:
I'm pretty sure you're right on the application. There are also steel and aluminum driveshafts. The aluminum one is much larger so might have clearance issues.
From car-part.com:
Thank you, but I'm hoping to buy this item private sale. I have a series of reasons why I'd prefer that, and without meaning to write a novel...basically I'm not interested if the vehicle was processed with a fork loader, I'm not interested if it has to be shipped, I'm not interested if I can't pay cash in-person after seeing it, and I'm not interested if I have to conform to typical business hours to get it.
I'm willing to spend the drive time and fuel, just need one to turn up.
I have a steel one and an aluminum one in central OH
Much appreciated.
or
go to joint clutch and gear.
or trans axle driveshaft distributors
DTS....or shaft masters in lincoln park....think he took over for one eye.
