Mr Ed
- Jan 5, 2010
- Automatic
*Solved*:
It was a corroded wire in the 3rd (cab mounted) brake light. The stealership found it, tried to charge me $345.00 to fix. We settled on $75.00 + tax!
Hi all,
My left (drivers side) turn signals dim and do not flash when the brakes are applied.
Things are fine unless I press the brake pedal.
Right side is fine, no issues. I replaced the bulbs and brake light switch (on the pedal), no luck. Seems like a grounding issue, but nothing seems out of place. The left license plate light is out, but that does not seem like it would be related. I disconected the trailer lights, but that didn't help.
Any thoughts?
Thanks!
Hi all,
Any thoughts?
Thanks!
