Driver's side cylinders not working??
alamogeorge
Trying to simplify my ongoing problem of no power. I think my original thread got a little confusing.
When I pull each plug wire, one at a time, the 3 on the passenger side make a huge difference causing the truck to shake and miss. The 3 on the driver's side make little to no difference at all.
The wires seem to ohm out good and the coil seems right. 0 across the primary at the connector and 10.8 I think it was across the pairs.
This problem was gradual over a couple of weeks. Manifesting itself first on hills and then on highway and now it never has power. I'm talking about hobbling along at 20mph...maybe.
I did have a bad pcv connector hose that threw several codes but that has been fixed and there are no codes now.
I know its difficult but also pull the connector off of each fuel injector while its running for a similar test procedure, sounds like you may have a clogged or bad injector or two or a fuel delivery problem. The good news is sometimes this can cycle the injector & they start working again, especially if they are really dirty.
JP02XLT
