robmurt90
Had the driver side beam out to put 4.56 gears in and now that it's all bolted back up the axle shaft is crooked. It slides into the carrier but when you put the spindle on its sitting crooked, as in its resting on the inner lip of the spindle. It rotates fine but I can't get the lock ring in there, it won't tighten down enough.
Anyone have any ideas?
