Driveline vibration
oughtsix
Okay. I have a vibration somewhere. Here's the story:
It starts at about 10 or 15 mph, and I havent run it any higher. There is slop in the center bearing, and the u joint immediately after, not much though. Barely perceptible. Got under there today, and found a bolt on this one that was missing. Replaced it. Still vibrates. although the vibration is different. So this tells me I'm looking in the right place.
the u joint after the center bearing had very little movement on one axis. This seems abnormal, yes?
So where do yall think i should start?
So you do not think it is the clutch?
I'm not sure how the clutch would cause a driveline vibration. Start with the parts you have found to be bad.
