CrimsonEclipse
- Sep 16, 2008
2003 B2300 93K miles.
When changing the fuel filter I noticed a slight movement on the drive shaft when pushed.
This year has no zerc fittings on the universal (or ball joints for that matter
) so I was never able to service them properly.
I'm also guessing that I can remove the drive shaft and replace the U-joints.
(hopefully something that can be properly serviced too)
Are there any "gotchyas" or tricks that I should know about before performing this task? and will the new parts have a grease fitting?
Thanks
CE
Thanks
CE
