Has anyone tried putting a 203/205 or 203/D20 behind an RBV trans? People have shafts resplined all the time and you can drill the 203 for whatever bolt-pattern you want. So I don't see why you can't have a 2wd output shaft resplined to Dodge 23 spline. Haven't measured but I would guess the RBV output is to small to respline to 31 spline. Then just put a Dodge input shaft in a Ford 203 range box, or run a dodge 203 range box.
