I have a 94 XLT with manual windows ,but im installing factory power windows & door locks from a 93 XLT & the power window door panels are damaged , & my manual door panels are good ,but need the hole from the regulator plugged. Any suggestions on what to do?
I was thinking about using a hole saw to cut a hole the same size in the damaged panel & epoxy it into the good panel & then either paint it or have the panel coverd in vinyl or other material.
any one have a pr of good electric window door panels? Not sure if this is just 93-97 or later years will work as well.
