locovaca
Well, my slave cylinder took a shit last week (thankfully in my driveway), so it's time to drop the tranny. Since I have 146k on the original clutch, I'm going to take the time to do that as well (although the clutch seems, to me, to be in good shape).
So right now I'm looking at:
1. Clutch kit from clutch city (comes with slave)
2. New fly wheel
3. Doing some freeze plugs
4. Probably doing the shifter bushings since I'll have it all apart anyway
So my questions are:
1. Is it worth replacing the master cylinder as well? I've seen people recommend it in other threads and others not.
2. Since I have to drop the driveshaft, is it worth replacing the U-Joints? Are those typical wear items to the point that they should be replaced every so often even though I have no problems with them? For $10-15 a joint, I don't mind dropping $30 now if it saves me hassle or a flipped truck 20k down the road.
3. Looking at the Dorman freeze plugs, do you get 3(+) in the kit or do you have to buy 3 individual 555-108's?
4. Anything else while I have it dropped? I just replaced the fluid before all of this happened, so that's already done.
Thanks
2. New fly wheel
Thanks
