Bob Hatcher
I am doing a 1979 4 barrel Holley carb/302 swap into my 2000 2wd Ranger and have some questions - I removed my original multi pin engine harness plug & entire wire harness from the firewall - since I am retaining all of the original gauges in my dashboard, I thought of plugging it back in only using the wiring to the original 3.0 water temp & oil pressure sending units so the factory gauges will still work - am I correct in thinking that will work and, if so, what other wiring would I need to retain? Would anything removed possibly hinder my stock ignition switch/ ability to start the truck type problems for instance? Also in my mind is my electric fuel pump operation going to continue if I keep the stock tank and use a pressure regulator to reduce the efi pressure to 7 psi - Thanks
