Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Where would one have to go to get the good stuff, full of the additives? Do auto parts stores carry the off-road only oils, or..?
on a microscopic level steel is porous, those metals fill in the pores providing a smoother surface for metal-to-metal contact, also making for more even wear. both of which is necesarry for flat-tappet camshafts among the numerous other metal-on-metal parts of an engine
What ever happened to 'Read the labels'??
from an oil anylsis that I have done with Royal Purple, there is at least 900 to 1200 ppm of zinc.
Ok here's the deal.
All API certified oils, SM and after, have reduced levels of ZDDP. Redline's oils are not API certified, therefore are not subject to these limits. Note that on the bottle they say "Recommended for API (whatever)."
A search on bobistheoilguy.com will show that Redline's oils contain more than enough ZDDP for a flat tappet engine. For example:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2141562
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1630856
Generally you want at least 1000ppm zinc and phosphorus for a flat tappet cam engine.
It made mention of break-in conditioners for use in new engines... Said adding that to your oil will do the trick. No idea where to buy this stuff though.
Anyone know wtf Im talking about? 'cause I dont.
Ok here's the deal.
