- Jul 27, 2008
- Alaska
- My credo
- Shit Happens...Then You Die.
I'm tired of fighting the parasitic drain on my battery. I thought I had the problem cured by installing a toggle switch on the offending circuit...but, no the battery will still go dead if not run or charged at least once a month.
A Master Disconnect Switch (Battery Shut-Off Switch) will cure this problem without having to disconnect the battery each time the truck will be parked for a week or two.
Does it really matter if the disconnect switch is wired in to either the Positive or the Negative battery cables? 99% of the on-line responses to this question say to use the Positive cable. Mr Gasket says to use the Negative battery cable.
Using the Negative cable just seems to be a safer option...no worries about shorting out on something.
Bueller...Bueller ???? May also mount a 5 watt solar panel to the damn battery and not worry about it.
