Distributor vs coil pack
Dog
I found a 3.0 topaz engine. It has a distributor. What block Orr intake differences would I run into using this engine in a 95 up with a coil pack. Is the dist hole covered up by the newer lower intakes?
Welcome to TRS :)
Topaz did use the 3.0l Vulcan engine, '92-'94, in FWD setup, transverse(sideways) mounting
Distributor was used on all 3.0l Vulcan engines until 1995 when it was replaced with a Cam Synchro tower with Cam Position Sensor(CPS) on top.
Install/timing here: http://www.therangerstation.com/tech_library/camshaft_position_sensor.shtml
In 1995 they also got a Crank Position(CKP) sensor, so you will need to change the timing chain cover, and crank pulley so that can be used on the older engine.
CKP is actually what replaced the distributor, it sets spark timing.
Timing chain cover has the mounting holes for the CKP sensor, and the pulley has the Tone Wheel the CKP sensor "reads".
Transverse mounted 3.0l engines used a different head gasket because coolant flow thru the engine was side to side, back of engine to front of engine.
In Rangers the coolant flow/hookup is all on the front of the engine so head gasket holes for coolant flow are different, sending coolant to back of engine then back to the front of the engine.
So it is recommended that you change the head gaskets when using a transverse 3.0l engine in a Ranger.
Many have not and have reported no overheating issues, but that doesn't mean that there are not hot spots in the engine causing long term damage.
So really up to you.
Be sure to put a sticker or something in the engine bay to remind you of what year the "new" 3.0l is, most parts are the same but not all
Changes over the years to 3.0l here: http://www.therangerstation.com/tech_library/3_0-build.shtml
Thank you for the response. I read that page about the interchange. And I am still unsure what would cover the dist hole in the block. im thinking that I would have to leave the dist in the hole. To block the hole upn unless the intake blocks the hole.
Nothing blocks the hole. A piece called the cam synchronizer goes IN the hole. The bottom half of it is basically the same as the distributor, but the top half is a little different, and has the little trigger piece for the cam sensor. It has to be there or the engine will run poorly if at all, and not long because that piece also drives the oil pump.
I'm sorry to butt in I'm new to the page I have a similar problem if ok with everyone I would like to know where I could ask my question I don't wanna step on anyone's toes here
Go to the general discussion forum, here: https://www.therangerstation.com/forums/index.php?forums/general-discussions.2/
Below the Banner and above the Notices/Stickies you will see "Thread Title" in light grey, click there and put in a title and then your question(s)
Remember to include the year of your Ranger or Mazda B-series, engine size, trans and 2wd or 4x4
Then click "Post Thread"
It may take a few minutes to an hour to actually be posted, as all New Member posts are screened to prevent RoBo posts or Hate Posts..............unless they are about Chevys :)
