Wanted Distributer
Barbara
Michigan
Where can I get a distributor for a 1985 ford ranger v6 2.8 duraspark
Just moved your post to the pats wanted forum... will probably get better looks here... Good luck!
I wish it was that easy. This part seems to be out of stock everywhere, even eBay doesn't have one available. I'm stuck in the same boat as OP right now because I have everything else on the way and can't find the distributor.
if you dont have any luck I'm pretty sure a friend of mine has one, pm me on here if you'd like me to go check
Do you still have the distributor? I'm in the process and can't find one.
I'll go take a look, it might take me a week or two to get up to the place stuff is stored, it's about an hour from my house.
Thank you, but I found one thanks to this forum.
glad you found one
Ok now I am in this boat, does anyone know if I use a duel vacuum and just block off the other port if that would work?
