disciplerocks's B2 build thread
Might be pushing it to get it done this weekend. Still have several things to do to the motor, pull and sort out the wiring harness, and pickup a couple things from the u-pull that I broke when pulling it. I am going to shoot for next weekend to start the swap.
On a side note, I misplased my winch remote in the dark the other night. Now I cant retract my cable.
Anyone local need a good running a4ld?
How many miles?? Jay might be interested if its cheap enough, he might want a spare...
SVT
Dang it, if you was local to East Tennessee, I would get it, I need a spare for my little BII
Robert
Rob, I'm sure we can get it to you if Jay doesn't want it. We've got TRS buddies in Evansville and Madisonville (right down the pennyrile pkwy), and at the bottom of the pkwy is Hopkinsville, which is next to Clarksville (which I am close to) and we have another member near Murfreesboro that I'm sure we could meet up with. Might take a week or two to get it there, but I'm sure its doable...
Dustin, how much you wanting for it so I can relay it to Jay??
SVT
Got valve covers back on. Tried to remove the oil pan, but there is one bolt I couldnt quite figure out. Ill tackle it tomorrow.
And btw I freaking hate exhaust bolts. Anyone have some tips for me for removal? I started to strip 2 on the head, so I tried removing the y pipe and broke one off in one of the manifolds.
Rick, I am not sure what to ask for it. I know what the junkyard wants for them.
are you pulling the manifolds off?
I would like to.
be ready for broken bolts in the head, ill probably put money on it that one or two will break. they suck....i got lucky when i did my headers and only 3 upper driver side bolts broke where you can drill through and put a bolt in with a nut on the back
i had no problem getting the bolts out of the head when i stripped the heads off for Josh.......
l8r, John
Well now I have to go to 3rd shift for 2 weeks starting this Sun night to train a new guy. Guess I am going to have to pull an all-nighter Sat night to get ready for it. May go ahead and pull the 2.9 this weekend now.
you wanna have a "swap party" after all????
l8r, John
I still have to work Sat morning. Then go in Sun night. I dont think Katie would be too happy with a bunch of people hanging out making noise while she is trying to sleep. We'll see. You are welcome to come up for the afternoon, but I haven't decided yet if I want to start the swap. I am going to wait till the motor is ready to drop in and it still needs a few things.
I finally got the exhaust manifolds off today. Broke one bolt, but its fixable. Better than dealing with the broken one that connects the Y pipe. Still haven't gotten my oil pan off. And I had planned on going to the u-pull today to get a power steering pump, and a sensor I broke, but since it is pouring I decided against it.
Made it to the u-pull and got my $10 PS pump installed. Also got the oil pan gasket, thermostat, and spark plugs done. Also drilled out the exhaust bolt and welded a nut on the back. Motor is now ready to drop in. Just need to pull the harness from the Ex and work on the 2.9 will begin.
The only thing I still need to figure out is the fuel lines. I know they are not supposed to match up, but I cant find any real info on what to replace them with.
I think these were due for a change
Coppers FTW!
those are some grungy plugs.......
l8r, John
