disc vs drum impact on ebrake cable
powell river
BC - CAN
Other
mazda b4000
Vehicle
Drive
hey yall,
ive got a 2010 mazda b4000, which for all practical purposes is a ford ranger 4.0l 4x4. especially for parts, as mazda has discontinued making parts for this truck.
it has rear disc brakes, from the factory, and i am fixing the seized parking brake. turns out everything up to the pedal mechanism is rusty and siezed. now im looking at cables, and im having a difficult time determining if the disc brake variety has variation in cable length from the drum brake version; and if so, what i need to get.
its been difficult to find any info on rear disc brakes in general on these trucks, mostly im finding info on conversions.
does anyone have insight on this?
If your truck is a '10 B4000, it is a unicorn: Mazda only officially sold 10.
Yes, the parking brake cables are different for the back portion cables (the front and intermediate are the same), and the right is longer than the left (although you could probably make 2 rights work..)
Good luck finding them - They seem to be rare even for the Rangers (again only '10-11 have the discs stock from Ford).
Cables appear to be different between drum and disc, and it isn;t jsut length, but all ends and attachemnts points. There may be a few small parts (clips, pins, etc) that are common, but most of them are going to be different as well.
Rangers got factory rear discs in 2010, and they only had rear discs for '10 and '11. If you buy parts for those two years, they should be the correct parts.
I'm not familiar with what don4331 mentioned about the Mazda production, but if your truck has rear discs it will be the same parts as the Ranger. Also not sure about the rare comment for Rangers. Rear discs might be rare amongst the full production run of 83-11 Rangers, but hardly rare for 10-11 models. All Ranger production in 10 & 11 had rear discs.
Ford parts sites still seem to list all of the parts for these (and carry most of them), even if you don't want to buy there, you can use the part numbers listed to find compatable aftermarket replacement parts.
thank you!
it is definitely a 2010 mazda b4000. just my luck. and explains why finding parts for this thing is a continual nightmare.
i  can probably reuse the rears, if i can get them out intact. its the intermediates that are truly screwed. and the strange connector adapter between the front and intermediates, havent seen anything that looks similar in the rock auto parts so far. unless it comes with, but isn't shown..
are there any other vehicles that run the same ebrake cable hardware as the 10-11' rear disc rangers?
thank you!
Not that I remember. The '10 -'11 Ranger rear axle is pretty much it's own beast. I was able to find replacement rear cables for my 2011 a couple years back. I don't remember where I got them tough. Rock Auto and Advance usually are pretty reliable on having what I need.
One word of caution, pay attention to how the cables are routed. It makes a big difference in being able to connect all the sections together, especially the right rear. And make sure the parking brake pedal is not set when you go to connect them all together as well.
Are you talking about the piece that looks like the black clip in the picture below. The piece that the front and intermediate cable ends clip into? If you order an OE Ford intermediate cable, I think it comes with that piece. Pictures of intermediate cables on the RockAuto site look like they come with it too. The one in the set pictured (Dorman 21126) might fit and work, but you'd have to try it and see.
nah i was wrong in my terminology, its a piece between the intermediate and rear inners. the piece that joins the 2 into 1.
I think thats fine though, and i just need to adjust tension by engaging the ebrake pedal a few times to take up the slack i pulled forward to work on things. havent done that yet because i need to get the other side apart and left inner rear cable in place before i tension everything. i also sucked it up and got new levers. i think trying to reuse the old rusty one i tried cleaning up, was a part of my problem. should have known, given the level of rust and neglect, and gotten all new parts to begin with. (its weeks shipping from rockauto to where i am)
those connector clips are ass*oles to get undone without the proper tool tho.
