backroad101
- Dec 26, 2009
- Automatic
So how does one separate the pump from the reservoir on the Saginaw? I removed the 3 hex bolts and removed the horseshoe bracket. Also removed the two 14mm bolts on the back of the pump. Only thing left on one large bolt that is on a block on back or reservoir (as noted with red mark in pic). Does that come off too? Tried a little bit but don't want to break anything. Bought this pump used and want to rebuild it before I install it
