- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Ok, so many of you have seen my ignition module mounted like this:
and shared your opinions on it not being the best idea, and I found out the hard way that it can overheat over in that dead air area and make it run like crap on a hot restart. I believe I fixed this issue saturday, I made a new mounting plate with the intake pattern copied in it to imitate the stock mounting location but figured there would be more airflow mounting it up instead of down, which meant mounting the module upside down which shouldn't be a problem. The mounting plate is 1/8" aluminum cleaned before the thermal transfer compound was put on, also picked up 3 computer heat sinks that I mounted on the back side. I'll try to get a picture tomorrow.
I also learned something about the ignition module. It's mounted with 3 bolts from the factory, DO NOT mount it with bolts in the 4 holes!!!! If you do, the engine won't even idle! Also, if anyone needs it, the threads are 4mm.
