So I'm still researching my options in a SAS on my IFS Ranger.
I originally was planning on using a Wagoneer Dana44 and running leafs.
I have a Waggy 44 sittin in my garage. Needs a lot of work but it could be used.
Saturday I met up with a neighbor who used to work at High Country 4x4 here in CO. He's running an explorer with 14" of suspension lift. This thing is a beast. Amazing flex.
Hes currently running an HP D44 out of a 73-79 Ford 4x4. He's using the stock radius arms, coil buckets, and for a while he was even running the original coils. No drop brackets, nothing.
I found a guy parting a 78 Full Size Bronco with the hp44. (This modle is based off of the 73-79 F-100 with the HP Dana44) He's asking 200 for the axle and all it's suspension components. He originally bought it as a donor truck for his other project, but ended up not needing anything.
I've looked around and running leaves up front would cost me more then going with this set up. It also would kill my attack and I'd have to fab a massive front shackle to get the arch right on the leaves and keep my axle placement where I want it.
To run the FSB D44, all I really need are brakelines, matching/upgraded ring gear, wheels (that I would have needed anyway) and steering linkage. The bronco it's comming out of is still running.
I'm passing up the 9" and I'm just planning on custom axle shafts for my 8.8"
Advice? Direction? Experience?
I like the idea of running coils, and yes, I have his help for any fab work/other things above my head at this point.
I think I'm going for it, unless some one can convince me otherwise.
Thanks guys,
Adam
Thanks guys,
Adam
