harriw
Hey guys,
When I got my truck back in Jan. ('94 ext. cab 4x4 w/ 4.0 and 5spd.), dealer did an oil change for me. I always thought they somehow overfilled it, as the dipstick has always read significantly above the "high" mark since I've had it (and that's with a mild oil leak). 3000 miles later I did my first oil change today and found what's going on. Added the first 4 quarts and checked the dipstick just for grins, and it's already above the full line. So, I let it sit for 15 minutes or so to let everything settle and checked again - still above the full line. Yes, I changed the filter too (motorcraft FL-1A), and let everything drain 'til it was just about done dripping.
So, are the dipsticks just off and I should go ahead and add my 5th quart? Or does this 4.0 take a LOT less oil than published (everything says 5 quarts)? Does the new filter get filled as you add oil, or does it stay empty 'til the oil pump pushes oil through it? It is a pretty big honking filter, but I don't think it'll hold a full quart...
Anyone else run into this? Thanks!
-Bill
-Bill
