dimensions of ranger D35 outer stub shaft
TireIron
Solid Axle Swap
Methuen, MA
can anyone with an extra D35 outer stub shaft take a few measurements for me? I'm looking for...
1. The length of the stub from the center of the joint to the end of the shaft.
2. The distance from the splined end of the shaft to the snap ring groove.
and possibly...
3. Diameter of the bearing surface.
4. Diameter of the seal surface.
5. Diameter of the splined section.
Thanks, Jason
yes it does, thank you much. It tells me the ranger outer is too short for what I was thinking. Oh well, the 19 spline shaft will be stronger anyway as long as the milemarker hubs can hold up to everything.
